Configures the cost metric of one or all interface(s) or an area.
| area-identifier | Specifies an OSPF area. |
| vlan-name | Specifies a VLAN name. |
| all | Specifies all VLANs. |
| automatic | Determine the advertised cost from the OSPF metric table. |
| cost | Specifies the cost metric. |
The default cost is automatic.
The range is 1 through 65535.
The following command configures the cost metric of the VLAN accounting:
configure ospf vlan accounting cost 10
This command is available on platforms with Base license, or higher, as described in the Switch Engine v33.1.1 Licensing Guide document.
